lt1 bellhousing behind a big block
Old Jun 28, 2010 | 09:18 PM
Kurtis2short's Avatar
i have a 68 chevy big block and right now i have a t-5 behind it io went with 82 flywheel was the only way i made it work but id like to do a t56 swap from a 95 but i dont care to fork out 600 to 700 for a damn bell housing if i go with a torque arm relocater kit can i use the lt1 belll housing i know the bottom two bolts wont have a place to go but think it would work ?
Old Jun 28, 2010 | 11:26 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: lt1 bellhousing behind a big block
which bottom 2 bolts are you refering to?
Old Jun 28, 2010 | 11:38 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
BBC/sbc/lt1....all have the same pattern for the bellhousing...
it will BOLT up fine... the clutch components will need to be mismatched to make it work...but it will work.
Old Jun 28, 2010 | 11:45 PM
The bottom two bolts that bolt into the pan on the 2 piece rear main seal
Old Jun 29, 2010 | 02:01 AM
Please get a pic of that posted I've never seen it.
Old Jun 29, 2010 | 01:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 93-97 LT1 T56 bellhousing will bolt to the MkIV block fine. It does not have any bolts that attach it to the LT1 oil pan; just a few small ones for a dust shield.
You will have to use a 153 tooth flywheel. A 168 tooth / starter will not work in that bell.
I hope you have your clutch release / flywheel setup figured out?
Old Jul 2, 2010 | 10:24 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Only ones I have saw with the bolts you are refering to are on a LS1 cast pan. A F-car T56 has a torque arm mount. Dean.
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
