Rear end Upgrading - 1989 RS
Car: 1989 Camaro RS
I apologize if this is a stupid question, but I have a question about my rear end and upgrading it. I have a 1989 RS 5 speed V6 and from what I know I have 3.42 gears (correct me if I am wrong). I have a parts car thats a 1984 Z28 Automatic V8 which I believe has 3.42 gears as well. Would one be better or different than the other? Are they both Posi?
Thank you
Thank you
Car: 89 Chevrolet Camaro RS
Engine: 305tbi
Transmission: 700R-4 Auto
Axle/Gears: Stock
Re: Rear end Upgrading - 1989 RS
a v6 rear end and a v8 rear end are going to have different gears, im not sure what the v8 gears are but their different than the v6 rear i call tell you that forsure
their is more redustion on a v8 rear end, to help explain:
if you have a v8 running on a v6 rear end
and he has a v8 on a v8 rear end
youd win the race because there is less reduction in a v6 rear end
companies do this so you can put more power from the lesser engine to the ground so your still fast
now if you could help me... how do u post a new thread???
Car: 1989 Camaro RS
Whenever you are in the exact board you want to post to just go towards the bottom and there will be a "New Thread" button bottom left corner.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Thank you
Thank you
89 is the transition year. A few 28-splines may have crept in late in the year, but most seem to be 26. Check the FAQ posted above for more info, should you be interested.
JamesC
JamesC
Engine: LS6
I didn,'t mean to give any bad info, but i have a rear out of an 89 that is a 28 spline. Got it at the JY, didn't look at the build date. It may have not even been the origional. It had a broken spider gear. I got it really cheap. I only wanted it to make a housing jig. Come to think of it, it may have not even been an 89. JY owner said thats what it was. Dean
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
