3.42 - 3.73
Subscribe
Jun 30, 2010 | 12:33 PM
I see that JamesC has a thread showing the difference between the 3.42 and 3,73 rpms at 70 mph.
3.42 (RPO GU6) / Approx. RPM’s at 70 mph--2255
3.73 (RPO GT4) / Approx. RPM’s at 70 mph--2463
If I replace my 3.42 rear end with a 3.73, would the rpm still only go up a couple hundred rpm. It used to be a V6 car, but now its a 350/350. At 55mph, It does 2500 rpm. Id like to use the 3.73 rear end for the posi unit plus the disc brake set up. I just didnt want to get into replacing the gears right away.
Thanks for any advise.
Reply 0
Jun 30, 2010 | 01:51 PM
Re: 3.42 - 3.73
I believe you are in the ballpark with your estimate. It all depends on the tire size too. If you are running stock wheels and tires, you should only see a few hundred rpm increase.
Step up to a 6 speed and you won't have to worry about the crusing RPM :-)
Reply 0
Jun 30, 2010 | 02:28 PM
Re: 3.42 - 3.73
you wont even really notice the difference between the two.
Are you swapping the entire rearend or are you just wanting the posi unit?
Reply 0
Jun 30, 2010 | 04:36 PM
Re: 3.42 - 3.73
I'm gonna do the whole thing. I found a 84 T/A w/ the G80 carrier and GT4 gears. A bonus is the disc brakes. I can get it for $200.00. It does have the B/W 5 sp and I could get the pedals, but I got alot of $$$ into my TH350.
Reply 0
Jun 30, 2010 | 04:37 PM
Re: 3.42 - 3.73
I just had it out and at 70 mph, the rpms are right about 3100. So a couple hundred more won't really hurt.
Reply 0
Jul 12, 2010 | 07:44 PM
Re: 3.42 - 3.73
my car runs at about 3300 rpms at 70 mph with my 3.45 9 bolt in 5th gear.
Reply 0
Jul 12, 2010 | 08:25 PM
Re: 3.42 - 3.73
my codes say i have a 3.42:1 rear, but based on those rpm readings, i am beginning to think that either my speedometer or rear end are lying to me.
at 75 mph indicated on my speedo, with a 74 confirmed on gps, running 255-50-16 tires, i am just a hair over 2100 rpms.
hmmm.
do you maybe not have lockup working properly?
Reply 0
Jul 12, 2010 | 08:35 PM
Re: 3.42 - 3.73
i have a t5 ,there is no lockup
Reply 0
Jul 13, 2010 | 04:03 PM
Re: 3.42 - 3.73
that was actually to shelad sorry.
but yours is pretty high too.
i couldnt stand running 3000+ rpms cruising at 70.
unless you are running a 1.8L engine with 10 lbft of torque, you are simply pouring gas out your tailpipe.
sorry to get off topic.
Reply 0
Jul 13, 2010 | 10:58 PM
Re: 3.42 - 3.73
I'm running a straight TH350 w/2500 stall. No lock up. No wiring. All of the harnesses and the computer have been removed. Also, 215/60-15 tires. I picked up the rear end today. Weather permitting, I will be installing it tomorrow. It was 115 degrees today.
Reply 0
Jul 14, 2010 | 12:06 AM
Re: 3.42 - 3.73
also it'll be quicker shifts going 3.42-3.73
Reply 0
Jul 14, 2010 | 10:41 PM
Re: 3.42 - 3.73
The rear end is in. I also changed the proportioning valve. I need to bleed the brakes still, then I can test it. As far as faster shifts, It already shifts too fast. My next project will be to figure how to adjust the shifting.
Reply 0
Jul 15, 2010 | 10:20 PM
Re: 3.42 - 3.73
Test drove today. Rear end works great. Still having other issues, but I believe its engine, so I,m moving to tech/general engine. Thanks all, Larry
Reply 0
Subscribe
