Slave Cyl question.
Old Jul 2, 2010 | 12:04 AM
BucketObolts's Avatar
Slave Cyl question.
Ok, I ADMIT I am a total n00b!!
I see my clutch slave cyl has NO bleed screw as such. Just what appears to be a brass plug screw.
Just HOW should one flush / bleed one's Slave Cyl on an 89 Firebird Formula with a 305???
HALP!!
Old Jul 2, 2010 | 01:32 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Slave Cyl question.
That internal allen head plug is the bleeder screw.
Be sure to hold a rag over it when your buddy pumps the pedal, or brake fluid will shoot everywhere
Old Jul 2, 2010 | 02:33 AM
AHHHHHH OK. Wanted to be SURE before I divided by zero and made the car blow up. LOL. Thank you!!!
Old Jul 2, 2010 | 04:23 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You can use that screw, but there is a less messy way to do it. Jack the car up and crawl under there and unbolt the slave cylinder from the bellhousing. Push in the plunger slowly and release it a few times. This will bleed the entire system in 3-4 strokes. I've used it several times on my Camaro when I had problems with the line from the slave to the masster and it worked great every time. Just make sure the little reservoir cup doesn't run dry. Oh, and make sure you leave the cap on it or you will shoot brake fluid everywhere.
Old Jul 2, 2010 | 09:00 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
This method works very well. I always empty the reservoir and and fill with new fluid before I start. Dean
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 15, 2015 06:06 PM
Ian Irvine
Sep 4, 2015 08:08 AM
