howling?
Old Jul 4, 2010 | 03:02 AM
King NothingSS's Avatar
Car: 2001 Camaro SS
Engine: no engine yet :)
Transmission: T-56 with z06 drive gears
Axle/Gears: most likely 12 bolt or 9" with 3.91
howling?
i just picked up a 87 Z28 with a t5. the car drives great except around 55mph the rear starts to howl and it doesn't get quiet until about 75mph. is my rear about to go bye bye? i'll check the fluid tomorrow when i change the oil in it, but any input is helpful!
Old Jul 4, 2010 | 07:33 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: howling?
The carrier bearings are shot you need to look for a complete assembly, your housing is likely warped from a P/O running it low on fluid.
Old Jul 5, 2010 | 02:44 AM
Car: 2001 Camaro SS
Re: howling?
oh great i wonder how much i can find a complete assembly for or i wonder if a rebuild kit will work hmmmm
Old Jul 5, 2010 | 01:02 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: howling?
mine was howling on deceleration, maybe on acceleration but my exhaust is too loud to hear it. next thing you know the rear end locked up because the pinion nut had backed loose and the pinion smacked the carrier. take the driveshaft off real quick and check how tight that bolt is on the rear.
Old Jul 5, 2010 | 01:22 PM
Car: 2001 Camaro SS
Re: howling?
i'll be doin that on wednesday
Andrew6.688
Dec 13, 2015 10:59 AM
64Chief
Sep 12, 2015 08:05 AM
Pontiackid
Nov 29, 2007 10:06 PM
irocz1228
Nov 29, 2007 07:58 PM
SLOW91TA305
Feb 24, 2002 02:47 PM
