My transmission nightmare
Old Jul 5, 2010 | 12:11 AM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
Hey guys, my car is giving me yet another problem..today when I was driving down the road, just after getting some gas in my car, I noticed that it felt as if it was running strange so I pulled into an apartment complex off the side of the road to change from drive to overdrive (I couldn't really stop in the street). Anyway, it still felt weird when I set it to overdrive but I said oh well and tried to exit out of the apartment parking lot by reversing but my car seemingly got stuck in drive..it wouldn't reverse.
I've never had this problem before and it took me almost 2 hours to finally get my car out of there (I had to get a cop to help me push the car up a hill from the corner I was stuck in so I could exit out)..it was an extremely embarrassing situation but at least I was able to drive it home after the incident..but now I'm too afraid to get back in my Camaro because it won't get out of drive (it won't even get into park, the shift **** will click when I shift into park but the car won't stop, it will just continue moving forward, so every time I need to park I have to pull the emergency brake).
I know I didn't give a really good description to my situation but I don't know how to simplify the wording. All I know is that my car won't shift out of drive and I'm not willing to drive my car until it's fixed. The cop said he thinks it could be a wiring issue but I honestly have no knowledge on transmissions or their wiring..I've been running into CONSTANT electrical issues lately and I don't know what to do.
Old Jul 5, 2010 | 12:57 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: My transmission nightmare
Its the summer of faild 700R4s aroundhere and you just joined an expensive club
Though Id check the cable for a quick fix.
Dunno why you stopped, you can change for OD to D while moving all you like n it won't care.
Old Jul 5, 2010 | 02:05 AM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Man some people just don't get it. In you other thread you were told more then a few times that since you don't have the computer hooked up anymore that you would need to do something about the TCC lockup before it damages the transmission.
You still think even after 4 pages of proving that everything the guy who sold you that thing was lying to you that it's still a 370HP motor? So he lied about everything but that? I'm not trying to be a ***** here just realistic, listen to the people you ask for help from. What you have there is a iron headed L98 crate motor taken out of a van that now has a burned up transmission behind it.
Before it's a complete write off check the fluid level in it. Maybe it's your lucky day and it has a leak somewhere.
Old Jul 5, 2010 | 02:38 AM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
I didn't read the other thread so I'm sure I missed it, but what was wrong with his tc lockup?
Also OP sounds like maybe you broke your shifter cable or linkage broke. Get underneath the car and make sure the shifter on the transmission is moving when you change gears.
Old Jul 5, 2010 | 03:50 AM
Doom86's Avatar
After re-reading your problem is does sound like you need to check the shifter linkage at the transmission. Hopefully it's just come unhooked.
For some reason when I read it the first time I thought it was stuck in D and not driving.
You still need to get the TCC sorted. There's a sticky thread on here with different options to convert it.
I would seriously consider picking up a haynes manual for your car too because this thing is a mess. They are only like 25$.
Old Jul 5, 2010 | 08:44 AM
ulmty's Avatar
Car: 1987 Iroc-Z Z28 Camaro
Engine: 5.7L TPI
Axle/Gears: Borg Warner 9-Bolt 3.27
Had the exact same problem a few weeks ago.
Get under the car and manually move the shift lever to see if it clicks through the gears, if so then its most likely your shifter cable. Cost me $27.01 at a parts store and a little bit of my time to fix.
After manually placing the transmission in park with the lever, I could shift down into R-N-D, but going back towards park it would move freely and not engage.
Good luck hopefully its an easy fix.
Old Jul 5, 2010 | 10:07 PM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
I've tried searching online to locate the shifter cable but I have yet to come up with anything..where could I go about locating the shifter cable to see if it's messed up or disconnected?
Old Jul 5, 2010 | 10:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Crawl under the car
Old Jul 5, 2010 | 10:14 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
it isnt hard to get up under to put it in reverse. but you might complain if getting dirty. ive gone thru 3 cables so far. going to get a gm one when i get up north.
its the cable i have my money on it. when they snap is hard to put from drive to park unless it just needs to be adjusted.
Old Jul 5, 2010 | 10:19 PM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
Originally Posted by Gumby
Crawl under the car
I know that part, but what exactly am I supposed to be looking for when I'm under the car?
Old Jul 6, 2010 | 10:06 AM
pontiac86ta's Avatar
Car: 86 Trans Am
Engine: 305 4bbl V8
Have someone move the shift from drive to park while you're under the car and you'll see the cable moving on the side of the transmission. It'll be pretty obvious.
I had a similar problem when I rebuilt my motor a couple of years ago. The tranny sat for a few months and when we reinstalled it it did crazy things. And we didn't open it up. When we installed it, apparently my cables got damaged or something because I could get it into D/OD and reverse easily. Park was a different story. It wouldn't go into park. To do that, I would have to crawl under and push the linkage to the park position. It was as if my linkage wasn't long enough.
So we went and bought a new linkage and ended up having to make a plate to modify how it mounted to the bottom of the tranny. So now, OD/2/1 takes a bit of work to get to.
I went around the block to explain that, but when you're under the car as someone is moving it get them to call out what gear they moved it to and you should see each stage it goes through. If it doesn't move, replace that cable. I promise it's not all that hard.
Old Jul 6, 2010 | 01:38 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I think that is your main problem, you don't know enough, not to be mean but any corn field grown bubba could crawl under a car n figure out where the cable is.
You need to just dive in or pay up to have someone else do it.
But its not your fault, not everyone was ment to work on cars.
UNless you want folks to think your a man hehehe
I know Im pickin on ya but its a simple as changing a tire, anyone "should" be able to do it.
Old Jul 6, 2010 | 10:37 PM
Car: 90 formula
Transmission: auto
Old Jul 8, 2010 | 07:34 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
cable that is mounted to the side of the tranny is your shift cable. on the driver side of the car. two bolts mount the bracket that it sits in to the trans pan. really thou if you look you will see how simple it is.
Old Jul 8, 2010 | 07:54 PM
83TransAmRECARO's Avatar
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
sounds alot like the cable....
Old Jul 15, 2010 | 05:48 PM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
Bump.
As everyone expected, it was the shifter cable that was messed up..I took it out today and I could pull the silver cable right out of the black rubber that coated it..the end of the cable must have worn out and snapped somehow. I'm able to change gears and put it in park when I move the linkage under the car, but I won't be driving this thing until I get a new cable..any recommendations on what brand to get? I found a Dorman model #04260:
http://shop.advanceautoparts.com/web...ci_sku=3925781
I don't know this brand or how reliable their parts are, so any recommendations are welcomed
Edit: Apparently this product got some really bad reviews..I'll stray away from the Dorman. What do you guys think of these instead?
http://shop.advanceautoparts.com/web...%7CGRP2060____
Old Jul 15, 2010 | 05:57 PM
ulmty's Avatar
Engine: 5.7L TPI
Stay away from the dorman if you can. It will work in a pinch to get you driving again, but it doesn't fit as well as the original and occasionally will get stuck between R and P and just hang in neutral. Sucks if you're tying to park and not roll into something. Try and find a GM replacement if possible.
Old Jul 15, 2010 | 06:08 PM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
I've failed to find a source to get a GM replacement for a shifter cable..all the sites for GM parts seem to only have other transmission accessories that are irrelevant to my issue, but I'll keep looking anyway. I found this and it looks to be a different model than the other Dorman:
http://www.napaonline.com/Search/Det...+50012+2012008
I know Dorman is the actual manufacturer of this product but would it be better than the other model? I've only found 2 companies that produce the shifter cable that will fit my car.
Old Jul 15, 2010 | 08:37 PM
gsmith's Avatar
Car: 1990 Camaro RS
Engine: 5.7L 350
Bump.
Does anyone know anything about the ATP shifter cable?
http://carpartscloseouts.com/TRANSHI...B000C8RCCO.htm
I know there's not a picture available, I haven't been able to find one. I would just like to know if anyone has experience with one of these (the model is the ATP y240). There aren't any junkyards close by and I'd rather get a new cable anyway..any advice is appreciated, thank you.
Old Jul 16, 2010 | 11:51 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Just go to the dealer and ask for the part. It may be discontinued though. If you really want quality, then get a B&M shifter for $200. It comes with a shifter cable.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
327IROC85
Sep 23, 2015 12:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
