Shattered governor gear and no shifting.
Old Jul 7, 2010 | 02:53 AM
Destructimus's Avatar
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
Probably a stupid question, but if the governor gears were shot, would a 700r4 not shift out of first at all? I still have reverse, too.
Here's the story behind this: After I removed the tailshaft housing to put my old speedometer gears into my new transmission, I noticed the governor gear on my old one was completely mashed. I got it stuck in the snow (I'm a retard) last winter and shifted too quick from forward to reverse. I heard a grinding noise, and when I got it out it wouldn't leave first. I described what happened to a local transmission shop and he said I blew a sprag and would need to rebuild my trans. I don't want to just replace this gear and put it in to have it still not work because something else might have broke at the same time, so I just want to make sure that a crappy plastic governor gear breaking will disable a 700r4.
Old Jul 7, 2010 | 08:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Shattered governor gear and no shifting.
Yes, without the governor gear the trans will only have 1st and reverse. No upshifts will occur. Note that this is a common issue (worn out gear) on high mileage transmission. Usually they end up looking like an apple core.
RBob.
Old Jul 7, 2010 | 03:47 PM
Car: 1992 Firebird
Hmmm... if it looks like half an apple core bitten in half, does it count? Lol thanks for the info!! Now I just need a cheap car to crash into the transmission shop for tricking me.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
