have a 92 rs tbi. po put a 77 350 w holley carb and turbo 350 trans. noticed the kick down cable is not hooked uo under hood. should i? and if so how?
i thought on a th350 it only controllled full throttle downshifts.
It's your call. You don't have to but sometimes it's nice to be able to automatically downshift. Are you using a b&m ratchet shifter? If so you don't really need it since you can go from d-2 pretty easily without the cable. I plugged mine off on the transmission because it kept leaking out of there.
Quote:
yup b&m shifter. thanks for the adviceOriginally Posted by elano
It's your call. You don't have to but sometimes it's nice to be able to automatically downshift. Are you using a b&m ratchet shifter? If so you don't really need it since you can go from d-2 pretty easily without the cable. I plugged mine off on the transmission because it kept leaking out of there. Supreme Member
Even with a built TH350 passing gear is nice, that what it controls.
