9 bolt rear - 1 wheel peel?
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I have an 89 GTA - L98 and I think I have the Aussie 9 bolt rear.
I only notice 1 blank line on burnouts - this rear is a posi, right so I should see 2 lines?
Do you think a fluild change could cure this? Is there a likely problem?
thanks.
thanks.
Re: 9 bolt rear - 1 wheel peel?
9 bolt has 9 cover bolts and a big rubber plug, easy to spot.
Worn cones & carrier, do a search there are many threads on how to fix it. Fluid change won't help, rebuild posi will.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
