TV cable adjustment
Old Jul 16, 2010 | 08:30 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
TV cable adjustment
So I put my new TV cable in and went to adjust it. Tell me if its ok.
I slid the movable D-shaped piece all the way back while holding the metal tang. I then opened the throttle to wide open, used a piece of wire to hold it there. I then slid the D-shaped slider back so that the cable was tight then released the metal tang.
I couldn't get the D-shaped piece to ratchet out so i had to use this method. If this isn't right then I will try to do it the more common way, I didnt want to force the plastic piece. From past experiences it never went well.
Thanks, Chas
Old Jul 17, 2010 | 12:05 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: TV cable adjustment
I would push in the sliding nipple a little more back in. Just a tad so that you can have some good line pressure at WOT. but your method sounds precise. I had the same issue to. the slider wouldnt slide out when I would mash on the gas pedal.
Old Jul 17, 2010 | 01:14 AM
Stephen's Avatar
Car: 87 GTA
https://www.thirdgen.org/detent
Old Jul 17, 2010 | 08:01 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Originally Posted by Stephen
Ya i read that but i explained y i couldnt use that method. when i would move the throttle to wot the TV cable would not want to slide. I didnt want to force any of my carb throttle mechanism and break something.
Old Jul 17, 2010 | 02:42 PM
Same issue with me. Just try it my way. Its basically the same but with a bit more work and finger strength.
Old Jul 19, 2010 | 07:20 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Its as far back as it can go now...should i give it 1 click of slack?
Old Jul 19, 2010 | 09:34 PM
Its really up to you. When you open up the throttle and the cable stops just before WOT, then your at the max. Now if you can open up the throttle even more without too much force on the TV cable, then this is max line pressure. If you TPI is in good shape, this is when you chirp the tires though every gear shift when you mash on the gas pedal.You can let the slider out one click if you choose too just to be safe.
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
