Burning Tranny Fluid
Old Jul 18, 2010 | 05:38 PM
Jcase350's Avatar
Car: 90 Camaro Iroc-z
I'm workin on my 90 Camaro Iroc w/ 350. I have changed my tranny fluid 3 times in the past 2 months or so. For some reason the tranny fluid is burning. I've had it flushed the 3rd time to make it wasnt just old fluid in there. Still burning though. Can anyone tell me what causes this?? Is it something I can fix? Thanks in advance!!
Old Jul 18, 2010 | 09:57 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Burning Tranny Fluid
is it truly burnt or just dirty?-if it's really burnt fluid will
be a golden yellow color
Old Jul 19, 2010 | 09:02 AM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
If it is burnt..... Id start looking now for a transmission. Sometimes you can pick one up for $250 or less. I got one for $100 once. Its always good to have a spare. Especially if you race or drive hard.
Old Jul 19, 2010 | 02:03 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
It might be the pump or the torq converter overheating and burning it.
Old Jul 20, 2010 | 05:53 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Ive found that these transmissions have a tendency to run hot even if properly serviced. I had a similar situation. My fluid wasnt burnt but was moving in that direction and smelled off. So...i installed a tranny temp gauge to see what was going on. Anytime i hit stop and go the tranny temps would rocket up and up and not really come back down once moving again while the engine would cool off again once moving. My solution was to get an aftermarket cooler and plumb it in using the factory in the radiator cooler as well. Now i have not seen temps above 190 even in the heat of summer stop and go.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
