Backing up binding noise
Old Jul 25, 2010 | 02:19 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
just got an 87 IROC. Rear disc, told it was posi (haven't had the chance to check on that).
When backing up there seems to be a noise that sounds like something is binding then releasing. Almost like a clunk noise upon rotation of the rear tires. Seems to mainly do it when turning the wheel (even slightly) and appears to go away if backing up straight.
is this normal (if it is a posi) or any idea what could be wrong
thanks
Old Jul 25, 2010 | 02:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Backing up binding noise
probably a good idea to pop off the diff cover and see what laying in it. sounds like something is broken in there.
or it could be brake related
Old Jul 25, 2010 | 07:56 PM
Car: 99 Formula
Axle/Gears: 342
thanks, planning on changing the rear fluid when it's not 110* out, this weather is brutal for car repair
Old Oct 10, 2012 | 11:54 AM
pasuperdave's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Axle/Gears: 10 bolt w/3.73
thanks
Did you ever figure out what was wrong? Having the same issues.
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
B_Dubya
Aug 26, 2015 05:09 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
