Another tranny leak thread
Old Jul 29, 2010 | 03:51 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
First off, new to the site and new to the camaro but not new to cars. I just bought the car yesterday (87 Iroc-z) and got it home only to notice two spots of tanny fluid on the ground passenger side. My driveway is a hill so I thought maybe these trannys have overfill holes. Pulled it into my garage which is level and checked again with the car off. I noticed a few drips starting and the bolts around the pan were wet.
This morning I jacked it up and tighted the pan bolts since they seemed to be abnormally loose. The gasket is cork so I didnt over tighten them just snugged up. As I was under there I noticed the tranny lines were wet and I could see drops forming by the threads. Now my question is, whats the easiest way to snug up on those flare nuts because there is no room to work with at all. Tried getting a wrench in there with no success.
Another thing I'm going to look at is the dipstick gromet because I've been reading fluid can leak out of there as well. Any other suggestions? This only happens once the car is shut off and sitting. While its running I have put it in park and checked but it doesnt leak.
Sorry for such a long post I would rather give as much information for people to work with than little to non. Thanks in advance!!
Old Jul 30, 2010 | 12:38 PM
Re: Another tranny leak thread
No ideas on tightening them lines?
Old Aug 9, 2010 | 10:05 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I used pipe thread tape on the compression fittings, stopped the leak from the cooler lines. Give it a try
Old Aug 9, 2010 | 10:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Lower the tail on the transmission a little and you'll have some more room to get a wrench in.
Old Aug 10, 2010 | 09:14 AM
Thanks for the late advice. I did exactly that, lowered the trannny and was able to get enough room to work. Ended up replacing the lines with hose and all new fittings. No leaks now! New pan gasket and output shaft seal as well. Good as new!
Old Aug 10, 2010 | 07:54 PM
iroczcamarokid's Avatar
Car: 1986 iroc-z camaro
Engine: 305tpi
Axle/Gears: 3:42
where was it dripping from? i think i have the same problem on my 86 iroc. i replaced the tranny filter and gasket thinking it was the cork gasket that cracked or just died it was goof over night but in the a.m there was a spot the size of a softball under the pan close to the passenger side any suggestions?
Old Aug 10, 2010 | 08:01 PM
One of the lines was leaking where it threads into the tranny. Crawl under and look around the lines. As my dad says, think like a rain drop. Start as high as you can and work your way down. You can also check the dipstick grommet. From what I've read it can also leak where the TV cable and speedo cable go into the tranny. Lowering the whole thing wasnt a huge deal either if you go that route.
Old Aug 10, 2010 | 09:53 PM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
4 Gaskets later, and lots of time on my back.... mine turned out to be a gromet too on the dipstick. I could never see the leak coming from it... looked clean. Tranny fluid is funny about finding its way out of a hole and you not knowing where it comes from... anyways I had the same leak for over a month after a new tranny went in.... no gaskets fixed it... RTVing a cork gasket into place didn't fix it... adjusted the gromet... no leaks of any type now.
Old Aug 10, 2010 | 11:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I always replace the tophat seal whenever I have to mess with the dipstick tube, or else it seems they love to leak.
billybob6110
Sep 23, 2015 01:30 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
TheExaminer
Aug 26, 2015 04:59 PM
Thornburg
Aug 25, 2015 01:46 AM
drathaar907
Aug 6, 2015 04:20 PM
