Help finding Ball Stud
Old Jul 30, 2010 | 09:49 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Hey guys.. Recently had some trouble with my clutch, randomly lost all pressure. Got under the car to see the Z-bar/Clutch cross shaft out of place and the Ball stud/ Pivot ball for the Z-bar sheered off at the block..
Does anyone know where i can pick one of these up or order one??
Thanks for the help!
BTW, its a mechanical linkage if it makes a difference/
Old Jul 31, 2010 | 03:22 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Help finding Ball Stud
Autozone has them... called a "clutch ball stud" on their website. $12
Summit Racing has them too, if you search for "clutch fork pivot ball" on their website. Just make sure to get a 13/16" thread if you ordered from them.
In a sad way, I like when little things like that break... It's my excuse to order from Summit, and other things "mysteriously" get added to the cart at the same time, lol!
Old Jul 31, 2010 | 12:58 PM
Axle/Gears: stock
The ones autozone list on the site don't quite appear to be like mine. Hopefully im wrong though, and I'll check when i head into work tonight lmao
And wouldn't the one summits lists be the stud thats in the bell housing for the fork, and not on the block for the z-bar?
any tips for removing the broken stud? I don't see any way of getting a drill in there, maybe cut a slot into it with a dremel and use a screwdriver?
Old Jul 31, 2010 | 02:28 PM
Oh.... Ohhhh
You're right, I was referencing you to the ball for the fork, not the Z bar.
Found one on Ebay: http://cgi.ebay.com/ebaymotors/3-4-S...Q5fAccessories
Old Jul 31, 2010 | 02:45 PM
Axle/Gears: stock
I had looked at that particular ball stud but im not 100% sure itll work, since it is listed for a z28 with 4 speed, and I have a 2.8 with the borgwarner t5 (from factory)
Old Jul 31, 2010 | 02:55 PM
If you can get the old one out, you can check the threads and see if the Ebay one should work or not. Other than that, I'm not sure what to tell you. Maybe a GM dealership would still have one in stock
Old Aug 2, 2010 | 08:01 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I assume the 2.8 uses the same ones as SBC.
The ballstuds were used since the 1960s at least and dealers tend to have them in stock.
Old Aug 9, 2010 | 11:55 AM
Axle/Gears: stock
well i found the supposed right ball stud for it. Looks exactly like the one I had on there before it broke, but trouble is, it seems too short, I can't get the zbar to reach it.
Im hoping that i'm just doing something wrong on my part, any ideas?
Old Aug 9, 2010 | 12:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
GM used those since the early 60s to the mid '80s... I'm sure they can get one. If not, any wrecker will have them.
Old Aug 9, 2010 | 12:14 PM
Axle/Gears: stock
That would be the ball stud I ordered and have here in my hand. Looks exactly like my old one, if my memory serves correct. I just cannot get the zbar to reach the stud, i fought with it trying to see if it was maybe just snagged but its not moving out and closer to the stud
redmaroz
Apr 25, 2017 07:14 AM
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
Magman
Sep 12, 2015 10:43 PM
transaero
Aug 31, 2015 01:14 AM
LT1Formula
Aug 20, 2015 09:36 PM
