700R4 shifting out of first?
Old Aug 1, 2010 | 08:57 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
My newly rebuilt 700R4 will shift into second gear @ about 3-4000rpm, even when manually in first. Any thoughts or suggestions? A transmission guy I am not!
Old Aug 1, 2010 | 09:48 PM
J91's Avatar
J91
Re: 700R4 shifting out of first?
Any help or suggestions would be greatly appreciated...
Old Aug 2, 2010 | 06:46 AM
J91's Avatar
J91
Bump....
Old Aug 2, 2010 | 09:54 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
possibly the governor weights?
Old Aug 2, 2010 | 11:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is normal, they are designed to do that.
For a fix so that 1st can be held to any speed, the TransGo reprogramming kit will do it. I don't recall the exact name of the required kit, but it does work.
RBob.
Old Aug 2, 2010 | 11:34 AM
J91's Avatar
J91
I guess I should of stated it is a non-lockup transmission. As for they all do that, I've never had this problem before out of 2- Z28s and four different trans ( 1- non lockup). I have heard this before though.
Old Aug 2, 2010 | 11:36 AM
J91's Avatar
J91
if it is the governor weights? What would be the solution?? Replacement, adjustment, again auto trans, are a weakspot w/me....
Old Aug 2, 2010 | 12:08 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I dont beleive it would be the govenor weights. The govenor limits any gear to about 5,500, generally by releasing pressure on the clutch when in manual, unless its modified. Second gear is held off by the manual valve when in manual first. I think you either have a misadjusted manual valve or an issue in the valve body. Check linkage adjustment.
Fluid pressure is either bypassing the manual valve or there may be check ***** missing or misplaced. You just had the trans rebuilt? By whom? Shouldn't they fix it for you?
Old Aug 2, 2010 | 02:08 PM
J91's Avatar
J91
Doc, thanks for the input. The shifter linkage is good and cable adjusted properly. What you are saying makes alot of sense. I purchased the Tranny from an eastcoast co. I am waiting on a reply from them. I will keep you posted as to what they say and what I find. When you say linkage, you are talking about the shifter or something else??? I've never done any valvebody work, but I think I may be learning real soon????
Old Aug 2, 2010 | 08:02 PM
Pro Built Automatics's Avatar
All stock 700R4's will come out of 1st at some rpm if held 1st gear long enough. Some earlier than others. The TransGo 700-2-3 Performance Shift kit will hold 1st gear to any rpm. I carry the modified version of the TransGo Performance Shift kit. Make sure the TV cable is tight at WOT. This can effect the ability to hold off the 1-2 shift when in manual low.
Old Aug 2, 2010 | 08:47 PM
J91's Avatar
J91
Well the mfr. is sending me two governors w/ lighter weights. They said to try them and to also tighten the TV one click when I install the gov. If this doesn't work, I guess it's on to the valve body and a shift kit. I would like to thank everyone for their input. If you have any thoughts on this, please reply....thx JC
Old Aug 2, 2010 | 11:06 PM
Who built the transmission? Where does it shift at, at WOT?
Old Aug 3, 2010 | 04:41 AM
J91's Avatar
J91
Moster trans. 1-2 shifting @4500, 2-3 @ 5800
Old Aug 3, 2010 | 11:16 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Hey J91, I was talking about the manual gear selector cable. The TV cable adjustment is also key to setting shift points.
Old Aug 3, 2010 | 12:45 PM
J91's Avatar
J91
Yes, both cables are adjusted anmd working properly. Gonna try the different gov. they are sending.....
Old Aug 6, 2010 | 03:43 PM
J91's Avatar
J91
Well Monster Trans, sent 2 Gov. While they work better, the premature shift problem in 1st is still there. After speaking w/ the mgr. they are sending me a beefed up valve body that he says will do the trick? I will have to pay shipping costs. Hopefully this solves the problem. They have been extremely cooperative and helpful throughout this process. I would like to thank everyone for their input so far....
Old Aug 15, 2010 | 07:25 PM
J91's Avatar
J91
Well i recieved a new valve body w/ a trans-go 2-3 shift kit in it, and a different 1-2 accumulator. The transmission is working perfectly. I wish i would not have had to of gone through the hassle, but it was worth it.
Hats off to Doc and the rest of the guys @ Monster transmissions, they were courteous, and helpful, through the entire process. Very good customer service. I would recomend these guys to anyone. Thanks for all of the help here. ASE Doc, and Probuilt you guys were right on. I've never done much tranny work internally, but things went well installing the new valvebody and accumulator...thx again JC
Old Aug 15, 2010 | 07:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, as I posted early on in this thread, it is normal for the 700R4 to shift out of manual 1st on their own. Good to hear that the trans-go reprogramming kit did the trick, as I also mentioned early on.
RBob.
Old Aug 15, 2010 | 08:07 PM
J91's Avatar
J91
Yeah, pretty happy w/it. Good solid shifts @ 6500rpm. Acts normal as can be under normal driving conditions...
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
