84 Z28 Posi?
Old Aug 1, 2010 | 11:11 PM
I_Roc_Chevy's Avatar
Car: 1984 Chevy Camaro
Engine: 305 4bbl
84 Z28 Posi?
I have a 1984 Z28. Some people have told me its posi, but I think its 1 wheel peel. Idk. It's in the shop right now or I would fire her up and figure this out lol. So does anyone know if it is or isn't? Thanks.
Old Aug 2, 2010 | 07:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 84 Z28 Posi?
From the 10-Bolt FAQ:
Do I Have a Limited Slip (aka Posi) (RPO G80*)?
Jerk the diff cover.** Open/Standard can be seen in the following link: https://www.thirdgen.org/forums/tran...1073-posi.html (posi?)
Gov-loc: https://www.thirdgen.org/forums/tran...rear-diff.html (3rd gen rear diff help!!)
Auburn: https://www.thirdgen.org/forums/tran...ing-axles.html (Tips/Tricks for Installing Axles, Bearings, Seals)
*Apparently, G80 was an extra-cost option which could be special ordered on any rear regardless of ratio.
**The most reliable way to determine if your car is equipped with a limited slip is to look. That said, this from big gear head: With the tires off the ground and the transmission in neutral, you should be able to turn one wheel and the other will follow in the same direction. This is limited slip or "posi". If the wheels turn in opposite directions, it’s a standard/open differential—OR a worn out limited slip.
JamesC
Old Aug 3, 2010 | 04:37 AM
Engine: 305 4bbl
Re: 84 Z28 Posi?
Thanks.
dbrochard
Jan 28, 2016 08:42 AM
djmarch
Sep 13, 2015 01:35 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
toyotekk
Sep 7, 2015 06:36 PM
