manual to automatic
Old Aug 8, 2010 | 03:16 PM
YELLOW IROC-Z's Avatar
Car: 86 IROC-Z
Engine: STROKED 305 4BBL
Transmission: SAGINAW TORQUE TUBE 4 SPEED
Axle/Gears: 10 BOLT 373 GEARS
manual to automatic
i swapped out my 305 carb. 700r4 auto for a stroked 305 carb. saginaw 4speed. engine and trans came out of an 82 camaro [factory] I put them in my 86 iroc. now i want to switch the 4 speed for the auto. took trans out of car and noticed differance between flywheel and flexplate. flywheel is 168 tooth and flexplate is 153 tooth. can i just buy a 168 tooth flexplate and bolt it up? or is there more involved.
Old Aug 8, 2010 | 03:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: manual to automatic
Either should work in the 700R4, I think only the 153 will work in the manual. You also have to match starters.
I swapped in a 1970's 350 with a 168 and my 700R4, just had to get the right starter (since stock I had a 153 starter on my old 305 TBI).
Falcon50
Aug 22, 2020 03:26 PM
Lbibb
May 5, 2016 12:00 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
