ANOTHER REAR END GEAR QUESTION
Old Aug 19, 2010 | 03:15 PM
alek72us's Avatar
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
IS THE A BIG DIFFERANCE IN BETWEEN 3.73 AND 3.42
IS IT WORTH TAKING THE 3.42'S OUT AND PUTTING 3.73'S IN WHAT ARE THE ADVANTAGES.
ALSO ITS A 350 TPI 5 SPEED
THANKS
Old Aug 19, 2010 | 03:23 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: ANOTHER REAR END GEAR QUESTION
I dont think it would be worth it. Not if there is nothing wrong with the 3.42's If you scroll down on this link, you will see where you can put in your tire size, trans gear ratio, and rear axle gear ratio and it will give you your rpm. You can expieriment with the two ratios to see how little of a difference there would be.
http://www.fbody.com/calc.htm
Old Aug 19, 2010 | 03:29 PM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
THANKS
THATS ONLY ABOUT 2000 RPM DIFFERANCE @75 MILES AN HOUR. I THINK I WILL STAY WITH MY 3.42.
Old Aug 19, 2010 | 03:31 PM
built91Z28's Avatar
No problem. Though I think you mean 200 rpm difference
Old Aug 19, 2010 | 03:32 PM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
RIGHT
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
