Wha, what? 91' RS 305 with sloppy manual shifter now STUCK!
Old Aug 22, 2010 | 09:16 PM
RedOctober's Avatar
Car: '88 Sport Coupe - 383 Stroker
Hey friends... thanks in advance for your help...
I have a '91 RS 305 with a manual (T-5, one would guess). A few weeks ago, I noticed that I shifted into first one time and was able to (unintentionally) push the shifter over to the right while in first. This brought the shifter to about the fifth gear position, but I was still solidly in first. If I brought it back and pulled it down, I would be in neutral. All other shifting was normal. It's done this since. Again, as long as I brought it back to the normal first gear position, shifting was normal.
Well, today I did some work on the car (unrelated to that) and when I started to back up, I noticed that movement of the shifter was VERY sloppy in all directions. It was then that I noticed that I could only move the car forward.
I'm hoping this might be a shifter issue that is external to the transmission. Is it possible something inside the trans has broken?
Thanks!
Old Aug 24, 2010 | 08:02 PM
RedOctober's Avatar
Re: Wha, what? 91' RS 305 with sloppy manual shifter now STUCK!
Help! I'm bummin' rides until I get it working!
Old Aug 24, 2010 | 08:06 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
pull the shifter out and look at it.
Old Aug 24, 2010 | 08:16 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
from what you describe it very well could be two things...both of which happened to me
1. the shiffter itself has broke...the welds on the plate can break and it will cause the shifter to hop out of the hole it rests in the trans.
2. the bushing in that hole has broke which can also cause it to slip out of the transmission
pull it out and inspect it
Old Aug 24, 2010 | 08:36 PM
RedOctober's Avatar
Thanks guys. The car is 30 miles from me; I had to leave it there Sunday. So anything I can think about or plan to try before I go out tomorrow would be good.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
