Transmission slipping
Old Aug 24, 2010 | 03:45 AM
PAIMON's Avatar
Car: 1989 Camaro RS Convertible
Engine: Need help identifying
What can I do about a slipping transmission
Besides taking it to a mechanic
I wanna fix it at home
Any advise on this
What can I do about it
What would I need to check
Thanks..
Old Aug 24, 2010 | 09:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Transmission slipping
You can rebuild it.
Old Aug 24, 2010 | 10:39 AM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
rebuild or replace... good luck
Old Aug 24, 2010 | 11:50 AM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
the only ways to fix it would be to rebuild or replace like the prev poster said but if you want it to just get by for now you can try some Lucas stop slip ...but if its slipping really bad you can also (this will only work for a little while) but you can dump 1/2 cup of brake fluid in the trans it will make everything swell up and the trans will grab and go ....but its also goin to eat up anything rubber in the trans so like i said it will get you by for a while but it wont last forever and the trans will need rebuilt or replaced
p.s
rebuild is NOT for the faint of heart do LOOOOTS of research and talking to people that know how to do the rebuild
GOOOOOD LUCK
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
camaronils
Sep 20, 2015 02:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
