Use RTV instead gasket
Old Aug 30, 2010 | 08:01 PM
iroc_valencia's Avatar
Any advice using only RTV for sealing the trans pan ? , avoiding gasket , i have to get it runing this week and can't wait a week till the damn gasket arrives.
I've heard opinions being a bad practice for the trans.
Suggestions ? thx
Old Aug 30, 2010 | 08:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Use RTV instead gasket
i cannot comment on whether its good or bad for the trans, honestly i dont see why it would be a problem.
if you use the RTV, make the bead on the pan and install, but just snug the bolts about 1/2way. let dry 24 hours, then torque down to the proper spec.
Old Aug 30, 2010 | 08:23 PM
hey bud, thanks for the reply
i've read about a micro vent hole on the pan rail of the 700r4 used for 4th gear servo , if it's clogged or filled , i'll be f*cked up.
Any input ?
Old Aug 30, 2010 | 08:32 PM
More info :
http://static.summitracing.com/globa...805_378905.pdf
STEP 13
Clean all old gasket material from oil pan and the case. Wash pan in solvent and install with new pan gasket supplied. Do not use any gasket sealer. Make sure the servo exhaust hole is not plugged or stopped up (See Figure 10)
Funny , huh ?
Old Aug 30, 2010 | 08:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by iroc_valencia
More info :
STEP 13
Funny , huh ?
never heard of that before. hmmm
Old Aug 30, 2010 | 08:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
and now your banned, tool
Last edited by AaronIROCZ; Sep 1, 2010 at 12:41 PM. Reason: removed disrespectful quote by other member
Old Aug 30, 2010 | 09:06 PM
hahhaha , owned
Old Aug 30, 2010 | 09:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Get the black material Delco gasket. Much better than cork. RTV is a pain when you go to service the fluid / filter.
Old Aug 31, 2010 | 09:38 AM
Pro Built Automatics's Avatar
Use the Duraprene pan gasket without any sealer. Most auto parts have them. They are black or brown in color.
Old Sep 1, 2010 | 07:34 AM
thx for the tip guys , i saw in the past those gaskets , they feel a bit harder than cork ones.
Hehehhehe , auto parts ? , for sure in the US , but not where i live (they sell econobox parts).
Old Sep 1, 2010 | 09:41 AM
If you only have access to the cork and rubber gaskets, then install them dry with no sealant of any kind, torque them "ONCE" to 65 inch pounds. DO NOT retorque them as this will destroy the gasket. This will do what you want here.
Old Sep 1, 2010 | 10:27 AM
Killerz187's Avatar
Car: '91 Camaro RS T-Top
Engine: 383 Stroker
Transmission: Bulldog 700r-4
My grandparent's old mechanic used RTV on the Oldsmobile's oil pan, and it leaked everywhere and was a pain to get off.
You'd be better off with a gasket IMO
Old Sep 1, 2010 | 02:25 PM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
The rubber gaskets always gave me issues. I RTVed a Cork gasket a few months ago to my new tranny.... not a single drop since. I went very very light, single solid line. I put the gasket on the pan first with RTV... let it sit up for a min or so while I did a line on the tranny. I avoided the drain hold mentioned above and went extra light around it with the rtv.
It works...
Did a bit of research on the forums before I tried RTV, some guys swear by it and have nothing but good results. Don't go hog wild with the **** though.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
