Clutch Master Cylinder
Old Sep 2, 2010 | 03:06 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Is this the stock clutch master cylinder. I am asking because the clutch seems to be a bit late to engage. I really have to press it all the way to the floor. Also it only seems to have one bolt hole that lines up.
Old Sep 2, 2010 | 03:50 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Clutch Master Cylinder
Can't see the clutch master in the picture. It is directly under the brake booster. If your refering to the resivoir only having one bolt hole line up, I've always seen it mounted on a bracket that bolts to the brake booster.
Heres a picture of my car. You can see the bracket on the booster. Where your resivoir is at now is where the fan and fuel pump relays normally are (I think its these relays).
Old Sep 2, 2010 | 03:52 PM
midias's Avatar
My mistake I thought the rest was hidden in the wall I am use to them being one solid unit.
FormulasOnly
Jul 23, 2018 08:47 AM
camaro1185
Oct 26, 2015 06:51 AM
meeklay812
Oct 1, 2015 03:46 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
mfp189
Sep 27, 2015 09:25 AM
