Doesnt wanna stay..
Old Sep 6, 2010 | 09:46 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
Doesnt wanna stay..
Hi, i have a 83 camaro berlinetta, 305, and im guessing 700r4 tranny. well, the prob is the shifter/cable. it goes from park to overdrive easily enough, but wont go any lower (drive, 2nd, 1st) and when i push it up too park from overdrive i almost have to use 2 hands to force it there, any reason why this is so tough and doesnt go easily into lower gears?
Old Sep 8, 2010 | 05:15 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Doesnt wanna stay..
Jack the car up and disconnect the cable from the trans. Now move the lever from one end to the other. See if it has a tight spot in it, or if it moves easily. If it moves easily, its probably the cable. If its hard to move, then its something in the trans. And even though I shouldnt have to say this, make sure the car is on jack stands while doing this. Dont want to have a jack fail or the car move when you take it out of park and crush you.
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
Tylermcclinton
Sep 17, 2015 07:50 PM
Veaceonee
South West Region
Sep 6, 2015 10:04 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Cacike
Aug 27, 2015 05:10 PM
