what gear ratio to run
I built a motor for a guy sometime back in 86 z-28, built the original 305 (his choice not to change to a 350)lol. has 700 r4 trans. what gear ratio would you put in car, he wants to light em up stop light to stop light. and save some freeway cruising. so wohat would you do as far as grear ratio.. thanks
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: what gear ratio to run
I have 4.10's, with a tpi 350/t-5 and it doesnt seem as easy to burn them as 3.42. I would say something like a 3.42 or maybe even a 3.73 would be good, 4.10 may be too much gearing for that. Of course, Id rather hook and move than burn and stand.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I've done a similar build. '85 Camaro, built 305, 700R-4, initially 3.42:1 then 3.73:1 rear gears. For what he's wanting, 3.73:1 is the right choice.
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
Question, I have a T-56 with a Ford 9" thats got 3.25 gears, withi the T-56 having like a 2.97 (?) first gear ratio, that'd give me speed off the line but low highway rpms, right?
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
