Bad Shifter Lever Damper?
Old Sep 21, 2010 | 08:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Does this plastic/nylon piece go bad? The one in the pic to follow appears to have a hole worn in the bottom. If the piece does wear, what are the symptoms (I have an occasional buzzing from the general area that I'd like to eliminate).
https://www.thirdgen.org/forums/tran...shing-t56.html
Also a bronze replacement is available:
http://cgi.ebay.com/ebaymotors/Bronz...s#ht_500wt_893
Any comments about the above replacement piece?
JamesC
Old Sep 21, 2010 | 09:03 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Bad Shifter Lever Damper?
The hole is supposed to be there. When I rebuilt my T5 2 winters ago I got a new one of those in the kit and it had the hole in the bottom. I really couldn't see any wear or differences between my old one with 103k miles on it and the new one that was in the kit.
I've heard the bronze one takes some slop out of the shifter movement, but haven't tried one myself.
Old Sep 21, 2010 | 01:39 PM
Drew's Avatar
If you shift with Hulk hands, theoretically the nylon bushing can crack, fall apart, etc. If it were me I'd replace it with a stock style nylon bushing. A metal replacement will probably wear faster, make more noise, etc and probably won't improve the feel that much.
Old Sep 21, 2010 | 10:52 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I'm not rough on them so I wouldn't care about going bronze on my own trans. What is key to prevent them from breaking is having it glued in securely. There's a loc-tite and a scotch brand adhesive equivalent that will hold it like OEM. RTV tends to let go after a while.
"shifter bushing sleeve" will find you a new plastic one on eBay for < $5 shipped.
It used to be that a dealer could look them up for a third gen without problem. But if you tried to look one up for a 4th gen, they would sell you the whole offset shifter block. That may be the case still.
FYI, T45, T5 and T56 all use the same one.
Old Sep 22, 2010 | 03:22 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Glued in? Mine wasn't glued in when I tore the trans down to rebuild it.
Old Sep 22, 2010 | 04:13 PM
JamesC's Avatar
When I was researching, I found that glue is recommended for the T56. My 85 shop manual, however, makes no mention of it--and several years ago when I'd disassembled my T5, there was no evidence to adhesive/glue of any sort.
JamesC
Old Nov 22, 2010 | 07:47 PM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
Just replaced mine. GM Part # 14105942. The cost was $8.94. I definitely noticed a difference in shifting. You could feel the grooves on the old sleeve when you moved it on the shifter ball. The new sleeve was very smooth on the shifter ball. No drag. There was no glue or grease on the old sleeve. It came right out. Attached are a couple pics of the old sleeve.
Attached Thumbnails Bad Shifter Lever Damper?-sd1.jpg   Bad Shifter Lever Damper?-sd2.jpg   Bad Shifter Lever Damper?-sd3.jpg
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
