84 berlinetta rear end info?
Old Sep 22, 2010 | 12:21 PM
gregsta565's Avatar
I'm getting an 84 berlinetta on friday with a 350, car has no rust, but has stock gears and rearend so im looking to get a posi unit for it, im wondering what size i need? im thinking its a 10 bolt 7.5? 28 spline? is that right? and what stock gears would it have? please if anyone could help me out i would appreciate it! thanks guys!
Old Sep 22, 2010 | 12:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 84 berlinetta rear end info?
Welcome to TGO, greg. A search will nearly always find you what you're looking for. Here are a couple of links to get you jump started:
https://www.thirdgen.org/1984-chevy-camaro
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Sep 22, 2010 | 05:10 PM
big gear head's Avatar
You have 26 spline axles. You probably have 2.73 gears. You can check the RPO code sticker on the bottom of the console lid and it will tell you what is in it. This is all assuming that it still has the stock original rear end in it.
If you can afford it I recommend going to a 3.42 gear and a Eaton Posi. Don't forget to get a good installation kit.
Old Sep 24, 2010 | 07:59 AM
gregsta565's Avatar
Ok, well I found a guy with a powertrax locker that's still like new that will sell me it for $150 that will fit my 26 spline axles, so this should work fine right? Also does anyone know if it wil take my stock gears for now, or will I have to buy different ones right away?
Old Sep 24, 2010 | 09:13 AM
The Power Trax will work just fine with what you have now.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
