Dosen't what to shift out of first!
Old Sep 23, 2010 | 12:18 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Hey guys I posted a question pertaining to a issue on Probuilt's website about a issue I'm having, and I have not received a response so I was hoping maybe someone on here maybe able to help.
Hi!
I have a 1988 IROC-Z with a 383 TPI and a 700r4 trans with a 3000 stall converter.
I bought a trans rebuild kit from Dana a little over a year ago. I believe the following link is it: ( https://www.700r4l60e.com/store/prod...&cat=52&page=1 ) I had a trans. shop rebuild it for me, and its been good til now. I've recently started to do more tuning to see what the car likes best. On Sunday I found a nice stretch of road in the country to test the car out. Everything seemed OK, but then after I got home, and had the car sit for a couple of hours while I was plugging in some data. I went out again and the car would not get out of first gear, unless I put it into neutral then back into drive at about 20mph. Which it then shifted into second etc. I also could not get it shift if I did it manually as well. It also would seem that once the car warmed up it would shift fine. I was told it could be the detent cable needs to be readjusted since I've playing with the idle so much, or the governor maybe sticking.
Tried it out this morning after resetting the detent cable. Car shifted fine at first, but then about a 1-2 miles down the road it started to not shift again, unless I put it into neutral then back in drive to make it shift. Again it won't shift at all in manual.
Old Sep 24, 2010 | 12:18 PM
Car: 1988 IROC-Z28
Re: Dosen't what to shift out of first!
The governor seems to be Ok. I found searching the forums of ProBuilt that it could be the throttle valve in the valve body that is sticking. If thats so can I just take it out and clean it up. Or do I need to replace it?
Old Sep 24, 2010 | 01:35 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
How your fluid level? If you bought the kit from Pro Built I'm sure the kit included the added modifications to keep the tv valve from sticking.
Old Sep 24, 2010 | 02:37 PM
Car: 1988 IROC-Z28
That was one of the first things I checked, and It was a quart low which I added. But it still acted up even after I did that.
Old Sep 24, 2010 | 09:57 PM
Mauiblubandit's Avatar
Car: 1990 Formula 350
Engine: 350 tpi heads cam full exhaust
Transmission: 700r4 corvette servo and 2800 stall
Axle/Gears: 342 out of a 00 SS
Im having the exact same problem right now, except neutral to shift to a different gear doesnt work for me. My trans was rebuilt around the same time, and same thing too I was out runnin it, came home let it sit then right away stuck in first.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
