Speedo jumps
Old Sep 24, 2010 | 03:12 PM
Spaceman77's Avatar
Car: Camaro Z28 1986
Engine: 4bolt 350
Transmission: th350
Speedo jumps
After I changed my th700 to a th350 my speedometer began to jump whats the problem how do i fix it? The speedometerwire i brand new. It works when i drive 50 mph and over.
Old Sep 24, 2010 | 03:29 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Speedo jumps
Are the drive and driven gears compatible?
Old Sep 24, 2010 | 04:37 PM
Spaceman77's Avatar
Engine: 4bolt 350
Transmission: th350
Re: Speedo jumps
I do not know. what type of gears should I use? I'm a newbie to this.
Old Sep 24, 2010 | 05:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo jumps
The TH350 gear housing isn't the same size as a 700R4, IIRC, so if you've swapped in a TH350, there would be a problem. Here's what you need:
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
Old Sep 26, 2010 | 12:42 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: Speedo jumps
i wont speak for compatibility, but the cable needs lube. graphite lube for lock cylinders will work. its a dry lube
Old Sep 26, 2010 | 01:24 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Speedo jumps
I used white lithium grease, on the speedo back where the cable hooks in and I also shot a decent amount in the cable using the straw but it sounds like you should follow james advice, even if you lube it you still need compatible parts
Old Sep 26, 2010 | 06:31 AM
JamesC's Avatar
Re: Speedo jumps
In the following link there's a procedure for cleaning and lubing:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
