Are the speedo gears the same on all 91 RS's w/ 273 rear end if so what kind are they
Old Aug 18, 2001 | 01:15 PM
Brad91Rs's Avatar
Car: 1991 RS and 1998 Trans Am
Engine: 6.0L(lq4) & 5.7L(ls1)
Transmission: 4L60e
Axle/Gears: 323
I need new gears to match my 323 rear and the guy at the gm dealership told me he needed the color of the gears. So if anyone can help me out I would be thankfull for it.
Brad
Old Aug 18, 2001 | 04:17 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
Crap i should have posted this in the tranny/drivetrain board. I must still be hung over, sorry about that.
Old Aug 19, 2001 | 04:12 AM
Omar's Avatar
Auto or manual, and what size tires?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 19, 2001 | 08:43 AM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
It is an automatic, and the tires are 245/50/16.
Old Aug 20, 2001 | 12:43 AM
Omar's Avatar
15T Gray Drive (8642620)
39T Brown Driven (25513046)
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Old Aug 20, 2001 | 07:40 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
Thanks alot.
Old Jan 8, 2004 | 11:42 PM
25THRSS's Avatar
wouldn't the correct speedo gears for that tire and 3.23's be 17/43?
Old May 14, 2004 | 12:14 AM
Omar's Avatar
You could use a 15/39, 16/42, or a 17/44.
Old May 14, 2004 | 08:35 AM
DanS's Avatar
Actually, if it's 91, shouldn't it be a electronic speedo? Which would mean no speedo gears to change, just have to get a calibration box...
Old May 14, 2004 | 08:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
$15 for a gear, or $300 for a box.....
Hmmmm..... I'm having trouble deciding this.... can I consult my financial adviser?
Old May 14, 2004 | 09:16 AM
DanS's Avatar
Good point RB83L69. I just didn't know that the gears could be changed on the electronic speedo's. Thanks for the info.
Old May 15, 2004 | 06:13 PM
cobb's Avatar
Car: 90 camaro
What would the gear be if i had 3.42 and a 25.7 inch tire.
Old Jun 7, 2004 | 11:50 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
the 91 is not mechanical so how would you calibrate with a new posi 3.27 rear? calibration box is the only answer?
Old Jun 7, 2004 | 06:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
With a differenr gear. Same as you'd use for an old 3.27 posi. The same thing you'd have to do if you put a good stock gear in it, like 3.73s for example.
Something drives the VSS you know. It's a gear. It fits on the shaft that sticks out the end of the VSS.
The Speedometer Magic Universal Constant is 1000 rotations of the cable (or VSS) per mile. Work it out for your tire size and gears. You'll come up with a ratio, somewhere near 1:3; depending on what trans you have, auto or stick, you'll be limited to certain combinations of drive and driven gears. About 7 in a T-5 or 15-19 in a 700 for the drive gear, and about 18-22 in a T-5 and 39-48 in an auto for the driven. Life is easier if you go look at the drive gear you've already got, and figure out how teeth would need to be on the driven gear to work with it, and see if GM makes such a thing. Sometimes you get lucky. Not always, especially if you started out with something really terrible, like even worse than 3.23 or 3.27; but it's worth a look.
Old Jun 7, 2004 | 08:50 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
yea... where are this gears located (sorry for the newbie questions)
Old Jun 7, 2004 | 08:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On the VSS.... at the back of the transmission.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
Numbah-1
Oct 2, 2015 08:27 AM
JSDaddy189
Sep 26, 2015 03:50 PM
