Need 700R4 expert help please!
Old Oct 4, 2010 | 07:56 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Hey all, I am in need of much help. I have been stuck on this problem for a few weeks now.
I'll try to keep the story quick.
My car was running fine, everything was working except I had an engine oil leak. I decided to pull my engine out and replace the oil pan gasket.
When I reinstalled my engine I started it and a LOUD screeching was heard.
I took off the engine belts, still screeching, took off my new timing chain cover to check clearance, no grinding, checked to see if the starter was grinding, starter is shimmed correctly and not grinding.
I had a friend start the car while I was under it. The noise is coming from the torque converter area. I did a little research online and decided to check the gap between the flexplate and torque converter. Mine had a larger gap than suggested so i put shims between them and started the car. I THOUGHT the screech went away. I started the engine again to check timing and revved it up and heard the screech again. The screech is consistent with engine rpm.
Does anyone have ANY suggestions?
The transmission is a performabuilt stage 2 with a 9.5" 3500 stall converter.
If you need any other info or have questions let me know.
Thanks,
Dennis
Old Oct 5, 2010 | 05:52 PM
Engine: 388 Carb
Axle/Gears: 4.10
Re: Need 700R4 expert help please!
Bump, no tranny guys could help here?
I plan on pulling the transmission besides taking it to a tranny shop, what could I do/ look for?
Old Oct 5, 2010 | 08:11 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Call Dana @ probuilt he's the guy you want to talk to. You can PM Pro Built transmissions they are on here, do a search...
djmarch
Oct 2, 2015 10:41 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
