1996 axle in a 1983 ?
Old Oct 2, 2010 | 07:54 AM
70's iron's Avatar
Car: 1983 Recaro Edition T/A
Engine: ex-CFI 305
Transmission: TH-700
Eveeything is in the question...
I'm wondering if it fits, if it changes the rear track, and if it will accept 3rd gen BMR 3rd gen rear suspension system
Thx
Old Oct 2, 2010 | 09:02 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 1996 axle in a 1983 ?
Thx
It is the same 10-bolt except for the axle housing length being 3" wider overall.
Old Oct 2, 2010 | 06:37 PM
70's iron's Avatar
Engine: ex-CFI 305
Okay ! Does it mean the rear track will be 3 inches wider ?
Old Oct 2, 2010 | 06:46 PM
DJP87Z28's Avatar
Yes, 1 1/2" per side= 3"
Old Oct 2, 2010 | 07:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following from the 10-Bolt FAQ might be an interesting read:
What 10-Bolt Will Swap into My Car?
Any third- or fourthgen. While a fourthgen rear is a direct bolt-in, it'll be 2" wider or a bit less per side (note the link below for more info about width). Also, take note that if the gear ratio is changed in a swap, for example 3.08's to 3.42's, the speedo won't read correctly unless the transmission's drive and/or driven gears are changed. If you have a T-5, note the following link for gears and a how-to: https://www.thirdgen.org/forums/tr...ve-driven.html (T-5 Drive/Driven Gear Info--Please Contribute)
The following link provides more info about the fourthgen rear/swap: https://www.thirdgen.org/forums/fa...-gen-rear.html (Thinking 4th gen rear? Swap info inside)
JamesC
Old Oct 3, 2010 | 01:54 AM
70's iron's Avatar
Engine: ex-CFI 305
Wow, I have to cancel the purchase of that 1996 axle !
Thank you guys...
Old Oct 5, 2010 | 11:04 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Thank you guys...
Either cancel it or swap in an entire 4th gen rear.
PurelyPMD
May 5, 2016 04:57 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
jtwoods4
Sep 3, 2015 05:39 PM
