87 700r4 spydometer cable mec or electric?
Old Oct 23, 2010 | 07:21 PM
mr.camaro's Avatar
Car: Red 86 Iroc-z / Black 90 Iroc-z
Engine: Mild 350 / Vortec L31
Transmission: TH700R4 / TH700R4
Axle/Gears: 3.42 / 2.73
Tranny from a 87 gta could it be mecanical? or there all electric in 87? thanks
Old Oct 23, 2010 | 08:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 87 700r4 spydometer cable mec or electric?
I'd guess electric. If you wish to swap the 87 into your IROC, which is mechanical, simply remove the VSS from the electric trans and swap in the mechanical housing (along with the proper drive and/or driven gears) from your IROC.
JamesC
Old Oct 23, 2010 | 08:07 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Yep, I think in 87 the Pontiacs received the electronic and the Chevs mechanical.
Old Oct 23, 2010 | 09:18 PM
mr.camaro's Avatar
JamesC
Thanks thats a good idea, but i have a 89 tranny in it as we speak
Old Oct 23, 2010 | 09:37 PM
JamesC's Avatar
Year shouldn't matter.
JamesC
Old Oct 24, 2010 | 12:01 AM
mr.camaro's Avatar
It is also electric though?
Old Oct 24, 2010 | 06:34 AM
JamesC's Avatar
As an example: 90-92 Camaros are electric (T5/700R4) and as a consequence have the VSS on the tail shaft of the trans. If you wish to swap one of these trans into an earlier car which is equipped with a mechanical speedo, you'd simply remove the VSS from the tail shaft and install the speedo gear/housing from the earlier car. The T-5 and 700R4 aren't interchangeable.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
L0tuS
Oct 4, 2015 08:07 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
