Swapping to a T-5, got two questions.
Old Oct 24, 2010 | 11:11 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
First question:
I currently have a set of 3.23 gears with a posi that I am going to build into a 91 Transam axle I got, is that a good gear selection? Or should I find and run 3.42 gears? I wont be running at a track and this will be my driver with mostly city driving.
Second question:
I read several threads about clutch sizes and what I can and cant run with a 153 tooth flywheel. I found two identical clutches on Summit, one listed 11" diameter and the other at 10.4 inches. So of course I would like to be able to run the 11" clutch. I have read that a vette clutch will work at 10.75". Will this 11" work for me, or should I just get 10.4" version?
Oh I forgot, I have a WC T-5 from a 90 V-8 car. I believe it has the 2.95 first gear and the motor is a crossfire 350.
Old Oct 25, 2010 | 02:36 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Swapping to a T-5, got two questions.
You need the 10.4 clutch. The 11 is probably for a 168 tooth flywheel, which doesn't fit in the V8 T5 bellhousings. The 10.75 1988 vette clutches are fine to use.
3.23 will work fine. I like 3.73s.
Old Oct 25, 2010 | 02:40 AM
91chevyrs350's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 carburated
Axle/Gears: 3.73 Posi
right on the button with that answer
Old Oct 25, 2010 | 09:20 AM
supr_fly03's Avatar
Car: 83 Z28
Ok, I will stick with the 3.23's I already have and see if I like it. I can always swap over to 3.42's at anytime since I do my own gears.
As far as the clutch, it is a $100 bump in price to gain .25" so I guess I am going to stick with the factory replacement setup. It is not like the Crossfire is a performance bench mark even with the 350 in it.
Thanks for your replys!
69 Six Pack
Oct 5, 2015 07:51 PM
midge54
Sep 2, 2015 06:27 PM
lt1z350
Aug 28, 2015 05:57 AM
Cacike
Aug 27, 2015 05:10 PM
CORV3TT3
Aug 23, 2015 11:26 AM
