will my th350 transmission hold up with aluminum heads and supercharger?
Old Oct 27, 2010 | 01:32 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
I have been debating about adding aluminum heads to my car but I wanted to know if the rest of my drive train can handle more power.
I currently have a stock 76 camaro 350sbc long block with a 142 supercharger installed. The transmission is a stock th350 from the same 76 camaro. and the rear is the stock rear end under my thirdgen.
I figure I can't be pushing more than 300hp with the current smog heads
if I change to aluminum heads will I need to upgrade my transmission and rear end?
I autocross the car and drive it on the street so not drag launching it.
any budget advice would be helpful
Old Oct 27, 2010 | 06:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: will my th350 transmission hold up with aluminum heads and supercharger?
without gobs of traction, the axle will live for a while. People ORR the stock 10 bolts with a lot more power that you have and dont usually trash the rear too often.
As for the trans, its old and wont last much longer. Time to rebuild it and upgrade.
Old Oct 27, 2010 | 06:16 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
It only has 60k miles on it. Does it still need a rebuild (will that make it live better behind the new power level?) What should I upgrade?
Old Nov 3, 2010 | 04:33 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Old Nov 3, 2010 | 07:51 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
th350s can handle some power.
http://www.hotrodders.com/forum/th35...ead-33874.html
Old Nov 6, 2010 | 12:51 PM
Big Dog Chevy's Avatar
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
Get you a Transgo kit and a 35,000 GVW trans cooler and you should be fine. For better peice of mind get a rebuilding kit with the red frictions and kolene steels then a 36 element sprag and you would be good for 600 hp. After that get you a th400. imo
midge54
Dec 27, 2019 04:14 PM
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
