What did i do wrong?
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Hey so i changed my transmission fluid and filter in my 1991 Camaro RS, 3.1L V6 with the 700-R4 Transmission in my auto mechanics class at high school. I took the pan off to drain the fluid, took the old filter out took the old gasket off, put the new filter in with the gasket, tightened them up in a diagonal manner, and then put 4 quarts of Dextron in.
Now my car wont shift from 1st to second, and it went 10mph with 3500 rpm. So i added another quart, but it still is only staying in first gear. The added fluid helped a lot i just don't know what i did to the transmission? It was suggested by the autozone guy that maybe i unplugged the vacuum shifter assembly?
Car: check
Engine: check
Transmission: check
Re: What did i do wrong?
Either the old filter seal is still in the pump, or the filter isn't seated all of the way into the pump. It takes a bit of pressure to push the seal & filter into the pump. IIRC, it sort of snaps into place when seating it.
Note that the 700R4 doesn't have any vacuum connections.
RBob.
RBob.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
RBob.
RBob.
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
Sounds like low line pressure. Your bands are going to slip pretty bad if they engage at all. Dont drive the car until you seat that filter.
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
I recall a filter change being 6 quarts. You might put your car on level ground, with a WARM trans, check the fluid level......and you probably know the car must be running when you check it.
