differintial oil?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
differintial oil?
tomorrow im going to be changing the gasket and oil but i need to know how much oil to get, should 1 quart be enough? please help
Re: differintial oil?
With the stock cover, it takes about 2 quarts. Exact amount depends on what gears and carrier you have. Buy 3 and take one back if you don't use it. I'd suggest Mobil1 since it's easy to find just about anywhere (Meijer, Wal-Mart, AutoZone, real parts stores, you name it)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I wouldn't bother with a gasket. Run a bead of silicone all the way around the cover and bolt holes and bolt it on. I normally use Permatex red RTV. I don't think I've used a diff cover gasket since the early 1980's.
Engine: L31 350
i have to stock cover and im going to go ahead and get a new gasket since this ones leaking as is and i dont want to have to re do this in a few years, and i dont have posi, its open
Car: 1987 Trans Am
Engine: LQ9/L92
i'd go with alky's recommendation - use RTV instead of the gasket. the cover's just stamped metal and not always flat enough to seal well the stock paper type gasket. rtv will do a much better job sealing the setup and last longer
Engine: L31 350
well i got the gasket and everyhting changed today, putting the oil in is being a PITA, its 30 degrees here so the oil is so thick its just taking a slow time coming out.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Next time your at walmart they have a pump with a hose that will screw right onto gear oil bottle. It works real good for about $3.00
skinny z
Oct 5, 2015 06:23 PM
