700r4 shifting odd
Old Nov 5, 2010 | 09:22 AM
stroked92's Avatar
Car: 89 hard top
700r4 shifting odd
been buggin me i figured i would finally make a post. i don't hammer the car all the time but it seems when i do it shifts better. when your cruising it shifts between 1500-1800 rpm annoying because it does not hold a gear unless you are on it. it will shift into od and have the converter lock up when doing 35 so it's just really boged down. it down shifts normal but it just seems it should hold the shift out further than 1800rpm am i crazy or is this normal?
Old Nov 5, 2010 | 09:33 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: 700r4 shifting odd
Make sure your TV cable is adjusted correctly. It can make your sifts too early or too late.
Here is a decent read on how to adjust it
http://www.73-87.com/7387garage/drivetrain/tvcable.htm
Old Nov 5, 2010 | 09:37 AM
stroked92's Avatar
Car: 89 hard top
i think i got it i will mess around with that on lunch thanks man
Old Nov 5, 2010 | 09:56 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
No problem.
Kep us updated!
Mark_ZZ3
May 24, 2018 01:02 PM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
HikoriYami
Sep 21, 2015 07:11 PM
