what to put behind my 454
Old Nov 8, 2010 | 08:29 PM
Jake88maro's Avatar
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
okay so im prett much just getting flustered now. i wanted to put the original t5 behind my 454 but the flywheel wont fit under the bell housing. well ive pretty much put the head aches of a manual tranny behind me. well i have a 400 turbo laying around but ita a nine inch tail housing. my buddys got a couple of 350 turbos and i could get a short tail 400 if needed. i'm just trying to go for the easiest swap possible but i'd like to know all i would need in terms of putting an automatic trans in. just some info my cars an 88 original 305 5 speed, the motor i'm putting in is a 454 out of a 79 2500 truck. stock so pretty weak power wise. let me know what you guys think. thanks alot -jake
Old Nov 8, 2010 | 08:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: what to put behind my 454
I used a long tail TH350 behind my 454. Worked with a stock 700R4/T5 driveshaft.
Old Nov 8, 2010 | 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The long tailshaft TH350 will be the easiest swap but behind a 454, I'd recommend finding some way to use the TH400. A new crossmember with an aftermarket torque arm helps with the swap. You just need to get the driveshaft shortened.
I've used them both but finally installed a powerglide. My BBC is drag race only with a lot of torque so I don't need a lot of gears.
MustangBeater20
Oct 29, 2022 09:20 PM
Kaweh
Aug 19, 2015 07:06 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
