whats this
Old Nov 11, 2010 | 10:51 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
whats this
Im talking about the weird looking spacer ring in this pic. Im doing an lt1 t56 swap and need to know if this is necessary http://i111.photobucket.com/albums/n...ird/Pix968.jpg
Old Nov 12, 2010 | 10:52 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: whats this
Thats a flywheel shim. That flywheel was probably resurfaced at one point and the shim was added between the flywheel and crank to make up for the amount of material removed. Some people say they aren't needed and that the hydraulic clutch will compensate, but personally I'd put it back on if it was on there before.
