700r transmission not working right
Old Nov 13, 2010 | 10:55 PM
mr2low's Avatar
i have a 1990 rs rearend went out replace it with a 10 bolt posi disc rearend went to test drive it now it will not shift out of first gear do you know what wrong with it any help thank you
Old Nov 13, 2010 | 11:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r transmission not working right
Check the governor gear.
Old Nov 13, 2010 | 11:31 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
check the adjustment on the T.V. cable do a search and you'll find how to adjust it
Old Nov 14, 2010 | 12:29 AM
Pro Built Automatics's Avatar
If you lost the other gears all at once, then it is most likely the governor gear has broke or stripped.
Old Nov 14, 2010 | 12:50 PM
mr2low's Avatar
will a 1989vette trans work in my 1990 rs
Old Nov 18, 2010 | 09:09 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Yeah you'll just have to reuse your camaro tailhousing
Old Nov 18, 2010 | 11:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The tailshaft on a Corvette 700R4 is over an inch shorter, and may not have the mounting holes drilled in the right locations in the case.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
milk
Aug 10, 2015 06:26 PM
