Building a 700r4 for 450 rwhp, what parts should I use?
Old Nov 15, 2010 | 03:00 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I'm rebuilding a 700r4 to go behind a HSR 383 that will be right at 400-415 rwhp before the 150 nitrous shot. I want this trans to hold this, not overheat, be ok in traffic etc. What's the best parts, why's, and mods to do to the trans?
Old Nov 15, 2010 | 05:04 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Building a 700r4 for 450 rwhp, what parts should I use?
transmissioncenter.net
Old Nov 15, 2010 | 07:09 PM
Axle/Gears: G92
Intresting, I want to build it and not buy it though.
Old Nov 15, 2010 | 07:18 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
700rs hate heat get the best cooler you can get your hands on
Old Nov 15, 2010 | 07:25 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
yeah, they have that option as well... scroll through the parts section, they have packages specifically for high torque applications...
Old Nov 15, 2010 | 10:44 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
www.pro-built.net
Old Nov 16, 2010 | 12:39 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Originally Posted by antoine
x2.
...anyone think the GM 5 pinion planets are overkill for 450rwhp?
i was about to recommend them, lol...
Old Nov 16, 2010 | 12:56 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Originally Posted by Tobias05
x2.
I do believe it's the torque that comes into play, not the HP... I would go with 5 pinion ...
Old Nov 16, 2010 | 01:58 PM
Axle/Gears: G92
Lol
Old Nov 16, 2010 | 02:06 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
x3 for probuilt i have the prostreet trans made to go into the 9's
Old Nov 16, 2010 | 02:10 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
probuilt, is this Dana's shop? I've read good things regarding Dana.. so that's an option as well...
Old Nov 16, 2010 | 02:46 PM
Axle/Gears: G92
Who is Dana? Never heard of them?
Old Nov 16, 2010 | 03:30 PM
Tobias05's Avatar
Dana is the owner of Probuilt. He posts on here. Good guy.
Old Nov 16, 2010 | 03:35 PM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
I can say this much, my 350 puts out about 425hp and I had my 700r4 done by a local shop that has built race trans's for me in the past. With a huge cooler and medium stall, it lasted one year and I think 5 trips down the strip. Hope you have better luck than I did. It set me back $3000.
Old Nov 16, 2010 | 07:43 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Pro-built!
This was my first time inside a 700R4 and it's already outlasted every 'professionally built' 700R4 I've had in the past. I've made about 35 passes between 4 dragstrip visits and driven on a couple of 200+ mile trips. I stay in the boost as often as possible when driving around town. These are the three things I did to ensure as much success as possible:
1> Listened to Dana's advice & instructions regarding replacing worn parts (especially the reverse input drum)
2> Bought a good ($700 Vigilante) billet torque converter per Dana's and other well informed transmission builders' advice for my crank torque being 600+ when my plans are done, 500 now (I believe going with a cheap torque converter has a lot to do with early failures on 700's)
3> I did a 50 mile break-in where I stayed out of boost initially and gradually worked up to full boost at the end of 50 miles.
I still need to put a cooler on it before summer gets back around. Love the way it shifts. Very pleased with it especially considering it was my first build.
Old Nov 17, 2010 | 12:28 PM
Axle/Gears: G92
What's dana's username on here?
Old Nov 17, 2010 | 01:20 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Pro Built Automatics
www.700r4l60e.com
Old Nov 17, 2010 | 01:35 PM
Axle/Gears: G92
Isn't that the same company?
Old Nov 17, 2010 | 11:25 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
I have a BowTie Over drive in my 69 Firebird. My 455 puts 358/370 at the wheels. I have been to the track and run hard on the street since 2003. It's probably got 80,000 miles on it now. It had a Great warranty and still works great. Keep it cool, (they cool a lot better with a lock up converter), keep the TV cable taught, change the fluid at least every year or so, if you decide to build, build an 87 - 91 get the super pump kit, the 5 wheel sprag, the good sungear, DO ALL THE LUBE UPDATES. Those can be found in TSB's. Lube failure is common in 700's, Use commercial grade clutches, put 9 clutches in your 3/4 pack. ANd make sure your core is as clean as you can get it! Lubguard is a decent additive, don't use anything else. It's the only one recomended by GM.
Good Luck!
Old Nov 19, 2010 | 01:39 PM
Axle/Gears: G92
I've tried calling and emailing and not Aswner.
italiano67
Dec 11, 2016 09:21 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
89-S-dime
Aug 12, 2015 11:57 AM
1nastygta
Aug 8, 2015 07:38 PM
