HELP!!! Lost O.D.??!!
Old Nov 19, 2010 | 07:35 AM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
Hi every1. 91 TA 350 L98 4L60
Runnin speed limit, hit brakes and put it down to 2nd on shifter at about 45 mph in addition to full on brakes...( to miss about 17 turkeys)
After that my Overdrive was lost!?? Ok, i dropped the pan and seen whether the linkage was unhooked but it wasnt so proceeded to change filter/fluid anyways. Reset the plastic sleeve with the tab that you can push to reset it, and put it at the correct length (according to shop manual) not chilton or hayes. i think that is on the kickdown cable-- (correct me if im wrong)--- but STILL NO O.D.!!!
Could it be that the cable itself stretched? I am really hoping that it is something external. And the fluid was in really good visual shape when i dropped it...
**STUMPED**
Old Nov 19, 2010 | 08:36 PM
Pro Built Automatics's Avatar
Re: HELP!!! Lost O.D.??!!
The first "three" gears are the same as before with just the overdrive being gone?
Old Nov 20, 2010 | 05:39 AM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
Yes. And also, i bought the car from a guy who rebuilt the L98. He said the OD doesnt work, so i dropped the fluid/filter right away, and OD suddenly worked!!! Then during this recent mishap it disappeared!! Maybe im thinkin cable issues or a sticking TV valve or ???
Old Nov 23, 2010 | 07:40 AM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
A friend suggested it could be the electric module box on the valve body, or maybe even the Govenor,,, from the quik OVERDRIVE to 2ND GEAR shift.... sound plausable??
ZZ3Astro
Aug 13, 2019 12:57 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
sandman92084
Sep 12, 2015 10:27 PM
