Pulled Trans for Motor Swap now shifts hard
Old Nov 22, 2010 | 03:51 PM
Pug89's Avatar
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
I swapped my motor now the trans shifts horrible. shifts to early at like 1700 rpm and shifts hard. I can not find the problem checked all the connections. Someone thought it might be a vaccum line to the Trans but i dont remember pulling off a vaccum line is there one and where would it be. It is a 1989 700r4 trans from a GTA with the 5.7 in it. i put the same motor in just less miles. Any help is great.
Old Nov 22, 2010 | 09:36 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Pulled Trans for Motor Swap now shifts hard
It is almost a guarantee that it is your throttle valve cable that is not adjusted correctly. This will toast your tranny in short time. If you have a manual it should tell you in there how to adjust it. I just removed and rebuilt the motor in my z28 and I actually went by a tranny shop and got some info on it because we burned up a 700r4 in another z28 because of an incorrectly adjusted tv cable. There is no vacuum line on a 700r4.
Old Nov 23, 2010 | 09:29 AM
Pug89's Avatar
Engine: 5.7 TPI L98
Thank you for the info ill try that.
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
