torque arm
Old Nov 22, 2010 | 10:44 AM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
torque arm
when removing my t5 do i have to remove the torque arm from the axle and do i have to remove my rear springs?
thank you and sorry if its a stupid question
Old Nov 22, 2010 | 11:42 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: torque arm
Just wedge a wood block between the body and the arm then remove the bolt from the tourqe arm mount then remove the trans as normal . If you don't wedge the arm it will rise up on you and it could hurt you if your hand or arm is in the way . No need to remove the arm or the springs .
Old Nov 22, 2010 | 03:47 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: torque arm
Either way, you're gonna have fun reconnecting it. There is a bit of pressure from the rear trying to twist up, causing the torque arm to do the same.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
