12 bolt disc brakes
Old Nov 23, 2010 | 03:25 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
12 bolt disc brakes
I obtained a 12 bolt from a 70 chevelle with 4.11 posi gears for too good of a price to turn down. From what I can tell, length wise its very close to swap in. I can swap the spring perches no prob and am going to fab up modified 4 link also to eliminate the torque arm. One thing I cant find out easily is if my factory disc brakes will swap over to this rear end. I did find out that the conversion kits out there work with both 10 and 12 bolts, so there must be similarities at the least.
Old Nov 23, 2010 | 05:07 PM
big gear head's Avatar
Re: 12 bolt disc brakes
The housing ends on all of the 8.2, 8.5, 12 bolt and many 7.5 Chevy car rear ends are the same, except for the full size cars.
Old Nov 23, 2010 | 05:19 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yeah they call the 7.5/7.6 ends small ends.. if it has the small ends they should bolt up fine
Old Nov 23, 2010 | 05:27 PM
The 7.5 had 2 different ends. The late '70s through the '80s they had a triangle shaped brake flange that used 3 bolts to hold the backing plates. Then they went to the standard 4 bolt flange, which is the same as all of the other rear ends. They all use the same axle bearings and seals.
Old Nov 23, 2010 | 06:04 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yes, the third gen disc brakes bolt up.
Old Nov 23, 2010 | 07:04 PM
dellman83Z's Avatar
sweet, thanks everyone for the help, much appreciated. Now, on to the hard part of putting it in, but at least that wont be until spring.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
overdriv
Aug 20, 2015 03:52 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
