Correct Flywheel for T-5 Conversion?
Old Nov 28, 2010 | 12:46 AM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
In the process of replacing my 700R4 with a T-5 out of a '91 305 cuin Firebird. So, I bought a parts car to do this swap; will the '91 flywheel fit my '84 305? If not, any help with what I need to buy?
Old Nov 28, 2010 | 01:34 AM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: Correct Flywheel for T-5 Conversion?
i know you need a 153 flywheel
Old Nov 28, 2010 | 07:58 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you need a 153 tooth flywheel. the 91 will be a 1pc rear main, and the 84 will be a 2pc. they will not interchange.
you can get a stock replacement flywheel just about anywhere.
Old Nov 28, 2010 | 11:56 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Yeah it is i just bought one for my 91 with a t-5 3 weeks ago
Old Nov 29, 2010 | 04:06 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
You need a 153 tooth for a 2 piece rear main seal and an internally balanced engine.
Old Nov 29, 2010 | 02:47 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Thank you all for the info, I'm off to my local salvage yard . . .
Old Nov 30, 2010 | 11:36 AM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I got mine new from autozone for dirt cheap. I bought one for a 85 305 car. 153 tooth, two piece rear main. It was $60 bucks.
http://www.autozone.com/autozone/par...819_78400_9284_
Stangski09
Nov 14, 2015 01:27 PM
Zane Story
Oct 8, 2015 12:40 PM
LittleFranks
Oct 7, 2015 11:26 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
