T5 surface fracture on reverse shaft mount
Old Nov 28, 2010 | 09:53 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Hey guys,
I just noticed this hairline crack on my transmission. I'm in the process of rebuilding it. I realize this isn't a high stressed area, but I'm wondering what to do about it. I don't want to go through all the hassle of rebuilding the transmission, and then having that guide snap and lose my reverse gear.
I hope the picture shows clearly where its located (for any that have looked inside a T5).
I also hope this picture attachment works!
Thanks for any feedback.
Old Nov 29, 2010 | 07:18 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: T5 surface fracture on reverse shaft mount
i'm by no means an expert , but i would be very afraid to use that case . it's my understanding that the center case is the weak point on our tranny's . i believe i saw a post a while back about an aftermarket center case that cures this problem . do a search . the T-5 is used in our cars , mustangs , and jeeps (maybe others) with no problems . they all have a different center case than ours . whatever you decide , good luck .
Old Nov 29, 2010 | 08:40 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
e-mail that pic to Bob Hanlon at hanlonmotorsports.com
He will be about the best judge of what you should do.
Old Nov 29, 2010 | 09:16 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I use to have a coworker who could TIG and that's what I would do then.
Now, I would look for a use a WC V6 T5 for the case and use that.
While you're in there, consider this: http://www.5speeds.com/t5.htm
Old Nov 29, 2010 | 01:14 PM
Bangin Bob's Avatar
Best I can see from that picture it is just casting flash and not a crack. I would finish the dissassembly clean it and look more closely. But I doubt it is a crack. New WC cases are very hard to find. We have some NWC cases (can't tell what you have from your pic) I also have G-force cases for GM T-5s on the shelf let me know if I can help you. Thanks Bob
Old Nov 29, 2010 | 08:24 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
I hope that is the case. I completely disassembled it and apparently never examined the case very well before I started throwing stuff back in. It is a WC tranny. I will be running this behind a mild 350 so any further guidance in what to do (maybe more pics will help), or how to determine if its a crack, would be great!
Attached Thumbnails T5 surface fracture on reverse shaft mount-pb280187.jpg   T5 surface fracture on reverse shaft mount-pb280190.jpg   T5 surface fracture on reverse shaft mount-pb280190_-_copy.jpg
Old Dec 11, 2010 | 11:30 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Anyone with further insight? I'm unsure how to proceed, and this has already cost me more than expected.
Old Dec 12, 2010 | 03:49 AM
rustrider73's Avatar
Car: chevrolet
Engine: lots of em
looks like casting flash to me also, keep building that handgrenade.
Old Dec 12, 2010 | 07:13 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
If it were me, I'd try to file away the flash, and see what happens. You'll have to flush the filings out of the case when you are done, though.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Oct 3, 2015 12:43 PM
88rscamar0
Sep 23, 2015 09:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
