Short Stick for T5
Old Dec 16, 2010 | 10:19 PM
98form's Avatar
Car: 87 IROC G92
Engine: LB9
Axle/Gears: BW 3.45
Short Stick for T5
Does anyone make a short stick for our cars? If so, please tell me where I can get one. I know about Lou's for 93-02 F-Bodies, but I'm not sure that one is compatible. I know I can get a Pro 5.0 or Hurst shifter, but I'm just looking to buy a shorter stick, not change out the factory shifter. This is for an 87 IROC btw.
Thanks for the advice!
Old Dec 17, 2010 | 01:51 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Short Stick for T5
Not possible, the factory shifter is a 1 piece deal, it's not like you can unscrew or unbolt the stick from the base plate.
The exposed stick, the piece your shift **** screws onto, is part of the same hunk of metal that fits inside the nylon bushing in the transmission and moves the shifter rail
Old Dec 18, 2010 | 09:04 AM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Some of the earlier t-5s had a two peice shift lever. I have one out of an 84 that is threaded together. The lower end is probably 3 inches and slightly curved. The top part that the ball screws onto is a straight 8" long hollow tube. I would think this part could be cut and re-threaded to shorten the length. I also have a newer one, '88 I think, that looks like it is two peice but I can't seperate it. It looks like some sort of rubber connection. That one also looks like it could just be shortened and re-threaded.
Old Dec 18, 2010 | 09:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
May I ask why?
JamesC
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
ndndndnd
Sep 28, 2015 08:00 AM
