I need urgent help!. V8 carb only works 1st gear
Old Dec 24, 2010 | 04:51 AM
SpaniardV6's Avatar
Hello guys,
Sorry but i need some urgent help.
My Trans Am V8 don't change from first gear. Only works its. If put 2nd ord D, or OD, only works the first gear.
I was looking for leves and found the power steering pump with minimum level but now don't have atf fluid to put. Can be this the problem or don't?
Last summer was changed into garage the transmission fluid and rear axle fluid.
Thanks you. Regards, and happy xmas
Old Dec 24, 2010 | 08:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: I need urgent help!. V8 carb only works 1st gear
Check for a broken governor gear in the transmission.
Old Dec 24, 2010 | 09:59 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Check the throttle kickdown cable, it might be pulled taught.
Old Dec 24, 2010 | 10:29 AM
torque_is_good's Avatar
Originally Posted by SpaniardV6
Hello guys,
I can't really gleen what you are trying to say with the above post; sorry.
Anyway, do you have reverse? Is what you are saying that no matter where you put the gear selector is that you only have first? I gather that it is an auto tranny?
If in fact you don't have reverse or other gears, stop driving it, either pull the tranny or flat bed it to a shop. You busted the sunshell or sprag
Old Dec 24, 2010 | 10:51 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Dead Transmission.
Old Dec 25, 2010 | 03:25 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Transmission: Auto 700R-4
Is this a 700r4 Tranny? Make sure the shifter cable is hooked up and not too loose. When I dropped a new engine in my camaro I left the shifter cable off and it would do the same thing. We had to hook it back up and give it just the right amount of slack for it to shift when its supposed to
Old Dec 26, 2010 | 01:43 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
mine wouldn't shift out of first in any forward gear, yurned out there were a few dents in the governor cover, just enough to keep it from spinning. do a search on "won't shift out of first". there are several possible causes.
Eric B
Old Jan 11, 2011 | 11:16 AM
SpaniardV6's Avatar
Hello and sorry for my delay in replying. I've been on vacation and even a few days ago I have not returned home.
Thank you very much for all your responses.
I will try to replace the Governator Gear after reading some posts about the problem of "won't shift out of first gear. "
But I find this piece on the website www.rockauto.com, which is one of the few pages that ships international packages I know.
Does anyone know where I can find on this page?. Thanks. Best Regards.
Old May 23, 2011 | 09:25 AM
SpaniardV6's Avatar
Hello,
I all this time, I can't locate a governor valve, and shifter cable looks "ok".
Now I see into eBay a governor valve for 700R4 GM (its valid for my Trans Am?. Into item specify the item its valid for all GM 700R4 except Corvette and Z28). I really don't know if I have got 700R4 (my car its a V8 from 1985). My transmission have overdrive.
Old Feb 22, 2012 | 05:57 PM
SpaniardV6's Avatar
Hi again,
I put a new governor, but dont solved the problem.
I get an eBay used valve body, and replace it, but dont resolve the problem.
I look for the TV cable, it works good, I test to see how it work while the pan was out of transmission.
This problem start when changed transmision fluid and filter on the garage.
I have read into this forum this is very bad for the car.
I have a Firebird from 1989 with V6 engine, work this gearbox into the V8? This firebird have overdrive, must be a 700R4 too?
Thanks to all
My car is dead, i hope it will run again, i love my car
87_LG4
May 18, 2015 07:09 PM
sootie007
Jun 16, 2014 01:22 PM
MKnight
Carburetors
18
Nov 18, 2005 06:03 AM
BigBadLou
Oct 7, 2004 06:42 PM
