need help asap
Old Dec 28, 2010 | 04:54 PM
86ztwenty8's Avatar
need help asap
I need to pull the trans out of my car.
Its locked up and stuck in fifth gear. Refusing to come out.
I dont wanna pull the bell housing. Just the trans and leave the clutch and everything in.
Is it possible.
Im getting a used tranny this week. and i have the car sold. Hes waiting to buy it till the trans is in it.
I wanna get this project started tonight.
Can someone advice me on how to do this?
Old Dec 28, 2010 | 06:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: need help asap
should work, since you install the trans with the bell and clutch assembly already bolted up to the engine. You will have to take the shifter off though.
just be aware that you cannot push in the clutch pedal while the trans is out of the clutch disc will fall out of position and it will be a PITA to get it right without taking the bell off. (Taking the bell off is not a big deal) just 6 bolts or so. The clutch and pressire plate are bolted to the flywheel and will stay in place if you pull the bell.
how old is the clutch? it might not be a bad idea to change it while its all apart, jstu throwing it out there.
Old Dec 28, 2010 | 08:03 PM
86ztwenty8's Avatar
Re: need help asap
the clutch is pretty new. No need to change it
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
